- ticki2ExplorerNot to sound discouraging and not saying it won't work but this is not a simple tongue weight you are dealing with . The weight is another 18 to 20 inches beyond the supertruss extension , and it will not have constant down weight like a trailer . As Wayne mentioned , it will most likely whip up and down going over bumps . If you could tie the vertical bar of the bike rack back to a strong enough attachment on the camper or truck it will greatly increase the stability .
- BedlamModeratorOne more alternative is a swivel wheel style deck instead of a trailer. It tracks your rear and does not pivot left or right. If you got into a real tight spot, you could disconnect it, turn around, and reconnect. They are spendy, but they do not require a plate or registration in most states.
http://cruiserlift.dudaone.com/swivelwheel
http://smarttrailers.com/
http://www.toy-tote.com/toy-tote
http://www.idahotote.com/ - Reddog1Explorer II
Crazy Creek wrote:
I now have a much stronger bike rack, and do have a cable with lock that ties the bikes to the camper jack. I too have a continuous rear camera. It was not much help when I lost the bikes. All was well till I hit the cement.Reddog1 wrote:
When you hit a dip on the highway, it real whips the extension. Just like cracking a whip. I lost two bicycles like that. There was a difference in height when they changed from asphalt roadway to the cement bridge. Fortunately, no one was hurt.
Wayne
Wayne
That is a concern. In addition to secure straps I think I'll tether the bikes to the main hitch. Worse case if they fall off....I'll drag them to a stop. My rear video is on all the time so I can monitor the bikes.
Thanks for the heads up. Lessons learned I guess.
Mike - Crazy_CreekExplorer
towpro wrote:
I just hook up the 7x14 Vnose and put the bike(s) inside.
I can take the KTM EXC690R, or the BMW R1200GS, or the KDX200 or all 3 :).
plus I have lockable storage for things from Adult Beveridge to fuel cans, generator, I even can carry 28 extra gallons of water in front of V nose
Nice looking setup you have.
This is a great option and one that I would consider if our style of travel was different. I envy all the room you've got.
We have a run and gun, off the beaten path, u-turn, don't stay in one place more than a day, thousands of miles kind of style. I'm going to try my best to avoid pulling a trailer. We'd probably take less stuff over hauling a trailer.
Bedlam wrote:
I also typically have more toys than I can hang off the receiver. I currently have a choice of using my cargo basket for two bikes or a scooter, a short flat bed trailer for two bikes and two scooters or an enclosed trailer for much more. I find I use the enclosed trailer more than any of the other options even if if it is not full due to the local wet weather plus the additional security through obscurity.
I am planning to hang more things off my SuperTruss and have put a bug into Torklift's ear of my desire for greater dead weight capacities in their extensions. I'm hoping they come up with a solution in the next couple of months, otherwise I will need to design something or reassess my future plans.
I've been thinking about a chain/turnbuckle from the bumper ball mount area to the end of the superhitch. I could weld a bracket on. This could help minimize downward vertical forces. I don't think I need it for what I'm currently hauling but we are always pushing the boundaries. - Crazy_CreekExplorer
Wayne
Wayne
Mike - BedlamModeratorCould you run a tire rail across the tongue of your current trailer to carry both the bike and buggy? Another thought would be to add a rear receiver to your trailer for a motorcycle carrier - You would need to pack the trailer tongue heavy to counter the bike hanging off the back...
- fpooleExplorer
Wayne
Yah, that's exactly my concern...
looked at possible support lines to the camper, but not excited about that either...
Don't want to tow a trailer just for a bike..
If I get a Trailer, it'll have a "Buggy" in it along with the bike...
Till then, still trying to figure it all out..
fun.. - BedlamModeratorI also typically have more toys than I can hang off the receiver. I currently have a choice of using my cargo basket for two bikes or a scooter, a short flat bed trailer for two bikes and two scooters or an enclosed trailer for much more. I find I use the enclosed trailer more than any of the other options even if if it is not full due to the local wet weather plus the additional security through obscurity.
I am planning to hang more things off my SuperTruss and have put a bug into Torklift's ear of my desire for greater dead weight capacities in their extensions. I'm hoping they come up with a solution in the next couple of months, otherwise I will need to design something or reassess my future plans. - Reddog1Explorer IIWhen you hit a dip on the highway, it real whips the extension. Just like cracking a whip. I lost two bicycles like that. There was a difference in height when they changed from asphalt roadway to the cement bridge. Fortunately, no one was hurt.
Wayne
44,056 PostsLatest Activity: May 04, 2014
