szglvs wrote:
I have seen motorcycle carriers that attach to a hitch.
Can you attach a motorcycle carrier to the back of Travel Trailer hitch to support a 600 lb motorcycle?
IMHO:
The short answer is no. Few if any trailers will have a robust enough rear bumper to support 600#. If you beef the bumper up you might be able to add a small bike/scooter but keep in mind that the rear bumper is the worst possible place to add weight. That much additional weight all the way back is a sure recipe for sway and the lever action takes the physics in entirely the wrong direction.
What is your tow vehicle? Any way you could load the bike in the back assuming it is a truck with sufficient payload? There are some toy hauler models out there that can handle 600+# but it sounds like you already have the trailer. Good luck.
:C
