dodge_guy
Mar 19, 2017Explorer II
behing19 wrote:time2roll wrote:
I have a similar 2001 F150 5.4L SuperCrew with now 190,000 miles. We go up and down the mountains all the time with a 7880 GVWR trailer. I did change the gears from 3.55 to 4.10 ratio. We are slow at times but never an issue of keeping up with traffic. Been over the Rockies, through Death Valley, Siskiyou pass to OR. Hardest climb was Nine Mile Canyon Road out of Pearsonville off CA395. Nine miles of 10 percent grade in 115F heat. Just avoid Ebbett's and Sonora passes in CA and you will be fine. Headed to Glacier this Summer. Keep the trailer GVWR within your tow rating for best results.
Awesome advice. We have the 3.73 ratio. Would it make a difference if it was changed to 4.10 or is that even possible? If so, what type of difference would it make?
3.73 will be acceptable. 4.30's will make towing a breeze. With a light weight trailer you will not need to change gears. If towing heavy (over 6500lbs) I would go to a 4.30. As 4.10 will not be a noticeable improvement. The van I stated I was towing with earlier had 3.90 gears. It would've performed much better with something a bit lower like 4.30's.
