gkirtley
May 23, 2016Explorer
Mounting & Wire Routing of In-Bed Receptacle?
Hi,
I am setting up my Dodge Cummins 8' bed for a future slide-in. I would appreciate getting some advice where to mount the in-bed 7-blade receptacle. The previous owner installed a fifth wheel wiring harness so it has a factory receptacle on the bumper and the other one in the bed which is not usable for a slide-in due to its location. I want to relocate it somewhere in front of the left wheel well.
I was considering mounting it as far forward as the 9.5' harness would allow but I have read where some people mounted them to be just in front of the wheel well and wondered if there was more cable available would there be any drawback(s) to going further forward? I was concerned that mounting the plug right in front of the wheel well might be in the way of using an inside access door.
Also my choices are to route the split wire loom forward along the frame and then over to the mount area or go directly from the back of the bumper to the space between the two bed walls and route it forward between those two walls. I wondered if anybody has any thoughts on the routing choice. Thanks.
