mobeewan
Jul 05, 2013Explorer
There may be a piece of plywood mounted between the studs where the mount tv here sticker is located. My trailer was new with fold down shelves. I used the push against the paneling along with an electronic stud finder to locate the studs and also determined there was a denser area between 2 of the studs where the shelf was mounted. Eventually I drilled through the bunkhouse wall at the edge to install an articulating wall mount with bolts and lock nuts to locate the tv above the existing shelf which I lowered 2-1/2 inches for the DVD player and the Sat Rcvr. I also did the same through a stud in the bedroom wall. The existing plywood backers in both walls were too low and only good for mounting the shelves.
44,056 PostsLatest Activity: May 04, 2014
