Diamondair's avatar
Diamondair
Mounting Items
Good Evening
I have a 2015 Jayco Jayflight TT and was fishing for some feedback on mounting items. This is our first travel trailer and 3 years owning it.
I have been nervous on mounting items with screws and been using command strips for everything. Most of everything is holding well but I was to add a mounted paper towel holder. This is a metal holder that has a type of spring load to it.
Now we all know those things take a beating from being pulled and yanked. I am looking to mount to the underside of my cabinet. The under side is hollow sounding. Not a solid piece of wood, which I think could be that way for some type of serviceability. I do not think the command strip will last long at all. A screw in m opinion would last but not that long just note enough material to grab on too.
So I ran across using pop rivets in my search on mounting something like this.
I am curious what everyone is doing to mounting things like this and other things. Possibly looking to mount a medicine cabinet in the RR exterior wall as well. Not sure what I could do there or if the rivets would work.
Does anyone have any recommendations on this?
  • I have always used SS screws snugged up to hold all kinds of lightweight stuff on the camper walls. The trick is to not spin the screw past the tight stage.
    Our paper towel holder is also screwed into the bottom 5mm plywood layer of a wall cabinet. No problem after 2 or so years.
  • You could probably through-bolt the towel holder into the bottom of the cabinet. I would use a fastener with a thin head so that cabinet items could be removed and added easily.
    FWIW, I have one of those Command Strips, Extra Strength that I use for hanging a framed picture. It hasn't budged in 6 years. I think the Extra Strength Command strips are used for mirrors and towel bars, etc.
  • My command strips started pulling the wall paper off the wall. All I had on it were rain coats and jackets. So I just drove a small nail through the command strip.
    I had the same thing happen with a small mirror, the wall paper started to pucker under the little command strip, so I push it back and used a small brad nail on that one.
    I have concluded the wall paper glue they used creeps when under pressure.
  • Use well nuts. Drill mounting hole, insert rubber encased nut. As you tighten the screw the rubber expands. I have used these in blind, hollow walls in my trailer for years. Available at any hardware store.
