tuna_fisher
Jan 25, 2017Explorer
bigfootford wrote:HMS Beagle wrote:
An update: now driven a few hundred freeway miles, panels appear to be staying put without problems. 200 watts seems to be plenty - even after the heater is run a bit overnight, if it is sunny, by 10 AM all is charged full again. I have actually unhooked the charge cable from the truck (another story) and don't seem to have to worry about power in the camper at all! One of the more worthwhile mods for your camper....
Those extra watts of panels will be nice when the weather is overcast and harvest is way down and you still recover ah used!
I removed the fuse for the charge line in my truck instead of disconnecting the charge wire from the truck's charge system. Easy to put it back in if needed. Why would you disconnect or remove the fuse on your solar systym?
Jim
44,068 PostsLatest Activity: Apr 17, 2021
