Lovealicia's avatar
Lovealicia
Moving Furnace Over
Hi there,
I have a bunkhouse in my TT that I am in the process of removing. Both the hot water heater and the furnace are under the bottom bunk, and my original goal was to remove part of the bottom bunk completely so I could stand on the actual floor and step up onto the remaining half of the bottom bunk that will be turned into storage. In order for it to work seamlessly, I would need to move the entire furnace over about six inches, and there is a gap between the water heater and the furnace so it might be feasible.
My question is, how complicated is it to move the furnace? It is flush with the outside wall for the vent, and the copper propane pipes are already bent at ridiculous angles to accommodate for the placement and I would have to figure out how to bend them the other way.
Should I hire someone to help me with this? Has anyone ever moved their furnace?
I can do the remodel without moving the furnace, but it leaves me with an awkward space and I'm willing to go the extra mile to get a better space.
