time2roll
Dec 19, 2020Nomad
Single battery seems small to support a 2000 watt inverter. I think I would want at least 2 and I would recommend 3+
Not sure I get the whole rewire issue. If the inverter/charger is under the dinette seat and you put the battery(s) in with it the wire should be minimal. If you have connections to the battery compartment the existing wire should be fine. The only big wire needed would be from battery to inverter and they would be very close.
