wanderingaimles
Jul 12, 2020Explorer
Yes, so long as you are only charging batteries and maybe one AC unit depending on the cord and the outlet (20 amp) that you are plugging into.
If your fridge is using AC power from an inverter, it MAY/PROBABLY/USUALLY has an automatic function that switches from inverter usage to run directly from the AC shore power, it that is the case, you likely will not be able to run the air conditioners with the reefer running also from the 20 amp circuit.
