Perrysburg_Dodg
Feb 24, 2015Explorer
gijoecam wrote:Perrysburg Dodgeboy wrote:
Yep looks like FCA and Ford are five years, 100,000 miles and GM is six years 100,000. Was sure they all had ten year coverage. But they all have the same issue with rust Ford
GM
Ram
Hope you don't think buying a Ford or GM will solve your rust problems!
Actually, buying a Ford would, in fact, solve the rust problem. The aluminum body doesn't rust (or so I've been duly-informed by the corrosion protection engineering manager). It may oxidize or corrode, but it does not rust. ;) Rust is, by definition, oxidation of a ferrous material.
Was referring to the pre-aluminum bodies, but yep no rust with the new bodies, just oxidation and corrosion. Think back to the GM's with the bumpers that would fall off from them no placing a plastic shim between the aluminum bumper reinforcement and steel mounting bracket.
