bigfootford
Mar 03, 2017Nomad III
If you pick panels with a 17.6 or less VMP there is no need to go with MPPT! Performance of PWM is just as good...
The next thing is to think about your panels and were to place them so you can still get around on your roof.
I too am partial to Morningstar... Either their PWM or MPPT with the remote control panel is great!
As a note... Some recommend a 2 to 1 solar watts to AH of battery....
I have 2 100 watt panels= 200 watts and 1 100ah AGM battery.... Because my Solar panel VMP is 23.5vdc MPPT is needed. My peak amps that I see in the summer is between 13 -14 amps.
I have found I no longer need 2 batteries after led lights, Wave 3 heat and a LED tv.
You need to do a audit of Amp Hour usage. That will help you determine your true needs.
We use less than 25 ah/day... Charging cell phones, laptop, Ipands, reading 1.-2 hrs a night and maybe a movie.
Jim
Jim
