- JTracExplorerI'm on my second set of Duraflap's. They are top notch.
- JAC1982ExplorerWe use Rocktamers mounted on the hitch too, that way we can take them off when not towing.
- buc1980ExplorerThe best are Gatorbacks but they are expensive.Can't find cheep and good so go for the best.
- BedlamModeratorI use Rock Tamers hung off the receiver. I like these because they are adjustable in height and width so you can even move them between vehicles or adjust them based on the rear sag of your load.
- Cummins12V98Explorer IIIDuraFlap are top quality. Customer support is top cabin. Customize as you like. These are a one of unless someone has copied since. They normally would not try to fit what I have on a Dually flap. Their shop laid it out and said ok.
- alexleblancExplorer
ScottG wrote:
These guys make the nicest mud flaps I have ever seen. They will adjust the mounting for any stock or aftermarket fender flares you have for a perfect alignment.
Have a full set on my Ram.
Nice! - Grit_dogTrailblazer
ACZL wrote:
Grit dog wrote:
Dura flaps.
Although if I had a big Dooley, I'd want to hang some real big rig flaps on the back, like with a Montana Big Sky logo or something.
Don't want the naked lady outline?
Only if in chrome with chrome weights!
Seriously if I had a dually it would have some big ole rubber Cummins mud flaps on the back! And if it wasn’t hauling a TC it would have stacks! - alexleblancExplorerhere's the gatorbacks on my truck and also a dually
- ACZLExplorerFWIW, This is what I had and or went thru. Old truck, '03 F250, had flaps attached to fenderwell. I added via cutting another set of flaps and additional 5"-7" of flap to orig flap. Then had a full width rubber flap attached to receiver to further aid in keeping debris off of coach. Worked well and w/o the full width flap, stuff didn't collect on rear portion of fender/under bumper. New truck, '15 F350, did same thing w/ flaps on wheelwells. Full width flap worked w/ old coach. New coach, due to shape of front end by landing legs, the full width flap won't work cuz it will hit the RV when turning. Surprisingly, with just the wheelwell flaps, nothing hits the front of the coach.
44,068 PostsLatest Activity: Jun 17, 2026
