Brandon327's avatar
Brandon327
Mud Flaps
What is the best mudflaps for a dually. Just got a new 2013 GMC 3500hd and i want to protect my camper from the rocks that the truck will sling out.
  • Scroll to the post with the white truck, these are what i have. http://www.dieselplace.com/forum/76-gm-trucks/127-3500-dually-trucks/440527-dually-rear-mud-guards.html
  • I used Husky brand. I found that if you check one pair will fit the front of the wheel as well as the rear. So you need two pairs.
  • I bought the factory ones for mine. They fit, look good and do the job. After a whole bunch of 70 + mph trips down gravel roads the flaps are still there so they are tuff too.
  • Is your camper a 5th wheel?. If so check out the hitch mud flaps. They attach to your lower tow hitch, if you have one. They can be adjusted to any width & also removeable when not towing. Some are called Rock Tamers. Good luck.
