Halmfamily
Nov 15, 2017Explorer
1) Bad battery or bad converter. Put a ohm meter on the battery while plugged in to see if the converter is charging the battery.
2) Water tank, yes put a valve on the vent tube to stop the water from siphoning out. Make sure you open it while filling your tank.
3) Set your thermostat to heat and fan setting to auto and A/C fan will not turn on.
I'll be a FR Kool-aid drinker. I am on my second FR and every issue I've had, and not many, have been taken care of by FR or the products manufacture.
Goodbluck
Goodbluck
