dodge_guy
Nov 15, 2017Explorer II
guidry wrote:
Yes, two batteries will help; but, if the AC is blowing and the heater is on, that will run a single battery down faster. You will need to check the vents to make sure one didn't fall off and is just blowing hot air under the floor somewhere, that would explain why it was cold too. Others gave you good advice on the water.
A/C runs off of 110V. If your not plugged in the A/C cannot run! The heat however will because it runs off of 12V (battery).
