goducks10
Nov 15, 2017Explorer
Sounds like you're using the pump for water from the fresh tank. Are you positive you're actually losing water out the overflow. It could be that the pick up tube for the fresh water tank isn't down in the tank far enough and you're not able to suck all the water out. When you get home do you drain the fresh water tank? If so how much comes out.
