time2roll
Nov 16, 2017Nomad
BATTERY and 12v system are designed to be plugged in while camping. You need to upgrade for off-grid camping.
FRESH WATER 40 gallons is not much but the vent pipe should be fixable. Probably less hassle to do this yourself.
HEATER do you have a heat pump or heat strip up in the air conditioner? Because if the actual A/C was coming on I don't think you would call it 'not too cold' as the actual A/C would be very cold when you need heat. As for the furnace vents it is typical for them to be inadequate. Ask the dealer to add some additional vents to the living space if you cannot do this yourself. Of course if you can find the existing is restricted fix that too.
Don't worry many new homes have issues too. Not just an RV thing. And good luck with the dealer or manufacturer swooping in with white gloves apologizing for your experience and making everything perfect. You may get some items under warranty but the rest is what it is.
