azrving
Jul 19, 2017Explorer
Keymastr
The O RV series look pretty good. Features like four gc2 battery trays and wired for 500 watts solar.
Jungle
My son and I shopped last winter for a large bunk TT and couldn't find anything that wasn't water damaged. He found an 2013 Open Range at Hoovers (Houston), I then went to look at it and found water damage. There was one little tell tale sign along a piece of bedroom trim. After looking at the roof I could only assume it was coming from around the AC. He then returned to look again with me and pulled on the trim and found black mold and that the upper panel was sort of soft.
I then wasted a day by going to PPL where they had the same 2013 O R with the same water damaged area but much worse. That damaged in the open range at hoovers could have easily been missed by many people. I looked at an Open Range (2014 or 2015 ?) with a badly water damaged slide. Looked like it wicking into a very poorly designed lower joint area. Look real closely under slides
Jungle
44,071 PostsLatest Activity: Aug 16, 2026
