RollingRockTX
Jun 18, 2013Explorer
#40Fan wrote:
I'd be pissed if mine didn't spin that long after shutting off. They are electronically controlled and if the computer doesn't command it, it isn't going to lock up. The on/off test doesn't prove anything other than it isn't locked up.
Best way to test these is to run the engine and command the fan speed to increase with a scanner. If it doesn't, then you know it isn't working correctly.
Easiest way to check without the scanner is to turn on the A/C. After a few minutes it should pick up speed.
I agree with you but I can also free spin it when off with zero resistance.
BTW I did the AC test and ran it for 10 min, fan speed never spun up.
