NRALIFR
Apr 24, 2016Explorer
Looks great, Jim! The boss and I are going to have to make an "on site inspection" some day.
It looks like the door required "quick turn" tracks, correct? That's the way my old garage was. There was only the height of the header between the top of the door opening and the ceiling joists, so the tracks had to turn the top panel pretty quick when it started opening.
I also like your new tractor a lot. That's the model that I've been looking at to replace the 15 year old JD-455 in my sig. When I bought mine, they didn't have a 4x4 compact tractor like the 1025 and 1026. I needed a front-end loader, but I also needed it to have a low COG so it would be able to maneuver around trees and work on my hillside safely, so the 455 is what I ended up with. It's actually been a very good machine, and you would probably be surprised if you knew how much material I've moved with it. I was just using it today to move a big pile of dirt and rocks.
Enjoy your new RV garage and toys!
