nephi007
Nov 01, 2013Explorer
my curse
Howdy. Never was able to master backing up well enough in 7 years of owning my Jayco to make the knot in my stomach go away, we we were always looking for pull through sites and generally found them.W...
Tvov wrote:
As to someone helping... I make sure that if someone is helping me back in, they ONLY tell me which way the rear of the trailer should go. If they start trying to tell me which way to turn the truck, things just get confused quickly.
As to hitches - different hitches don't really change backing in (although I've never used or even seen a "Pullrite" hitch), BUT remember to disconnect sway control bars. Sometimes backing into tight campgrounds can mean almost jackknifing the trailer, which can bend a sway control bar. Also, depending on your setup, it may be easier to disconnect weight distributing bars before backing, in case when you are done the truck is at an odd angle to the trailer.
Practice, practice, practice!
