Big_steve's avatar
Big_steve
My head is spinning.....
The more i read the more confused I get.
My TV is rated at 8450 lbs towing cap. My payload is listed as 1670. Figure 400 lbs for passengers, and my payload is 1270.
Can I tow a trailer that is dry weight 5580, GVWR 7000 (payload 1420) with a hitch weight of 650 lbs?
At first I thought I could, now it looks like I'm over.
What do y'all think? Thanks
  • Short answer, yes, it's fine.
    Longer answer, you "could" get a bigger, higher towing capacity truck and it would be more effortless for the truck and a HD truck would be more effortless for you, given your inexperience towing, but you're ok with what you got.
  • BenK wrote:
    Since you don't have the trailer yet, the formula should look like this:
    Trailer weight (max) <= GCWR - Actual TV weight - Hitch system weight
    Okay, thanks. Crunching numbers while considering water, passengers and the loaded hitch leaves me just under 400 lbs shy of max. I don't think clothes and food for the two of us would weigh much, but of course a generator and grill will tie up a lot of the reserve. I cannot upgrade the truck. So I have to decide if I want this trailer or ramp the trailer weight down some.
    Thanks
  • Gotta go out and weigh your TV fully loaded as if ready to tow. Total and each axle weights
    Then gather TV's GCWR, F/R GAWR...and...trailers actual tongue weight fully loaded. If you don't have that, then the brochure tongue weight and note the dry weight..that will provide a ball park percentage tongue weight when loaded....unless it is a toy hauler, they have very different tongue weights empty and loaded
    Now simple math to figure using this generic formula:
    GCWR >= actual TV weight + Hitch system weight + Actual trailer weight
    . If you don't have the actual trailer weight yet, use it's GVWR as the max it will ever weigh
    There will be a need to check the actual tongue weight + Hitch System weight + TV's actual rear axle weight. That should be below the TV RGAWR
  • LanceRKeys wrote:
    Yes you can tow it, people do it every day. How good of an experience you have and how enjoyable the ride will be is a whole different thing.
    Are you saying you think it's doable, but not a good choice then?
  • 2016 ram 1500 5.7 hemi, 3.21 rear reg cab, 8 ft box. 1670 is off the door sticker. Tow cap confirmed with vin on Dodge website, and dodge tow charts. Thanks
  • Yes you can tow it, people do it every day. How good of an experience you have and how enjoyable the ride will be is a whole different thing.
  • need more info about the vehicle such as is it a truck ?
    What size engine
    what drive axle ratio
    brand of vehicle and year model
    Others will have question also
  • Is 650 pounds of tongue weight dry? More if wet and loaded. What’s the WDH hitch’s weight? PS...I believe you are going to be ok.
