Doug33
Jul 07, 2015Explorer
my near disaster
We had a great vacation camping at Delaware Seashore State Park. The best part was walking a few hundred yards from the campsite to the beach (and not having to pay to park!). Last Friday we packed ...
Doug33 wrote:RVcircus wrote:
I've had a connector come out and now use a zip tie to keep it tight.
As for the axle moving on the leaf spring, I'd take a close look at it if you haven't already. There's a pin that goes through the spring pack and into a hole in the spring pad on the axle. This should prevent the axle from shifting, but I suppose it could jump this pin if the u-bolts were loose or it could have sheared off. I'm thinking the suspension may have been binding causing the appearance of it being off (I hope).
As far as the electrical harness, I am also considering doing it myself. I assume I'd have to replace it back to the electrical box mounted to the frame? Or does it get spliced in just past where the damage occurred? I don't think I'd be able to do a splice job mid-wire.
