towpro
May 08, 2015Explorer
The air grid is like plastic mesh on one side, but the back material side also breaths.
But after I finished I was thinking "where is this moisture I am trying to combat coming from"?
If its coming through the mattress its going to hit the Reflectix and stop because its foil. So I moved the problem up to between the reflectix and the foam mattress. Maybe I should have put the foil on the bottom, than the air gap between the mattress and foil with materiel side up :(
Edit: This morning we changed the order. Mattress sits on air gap with materiel side up, then Reflectix, than factory carpet.
44,025 PostsLatest Activity: Feb 26, 2025
