Zeppe807
Jan 15, 2015Explorer
Bob/Olallawa wrote:
You said a 4 ft rack off the back. If that rack is loaded down, it will lighten up the tongue weight and could be the cause of the sway. Tires and tire pressure could be part of the problem. Don't get the Hensley until you figure out the sway problem.
The sway is there when the rack is loaded or unloaded. I only put some fire wood, and or a wagon or empty barrel or blue tank caddy. All but the wood is light. It would be a 1:1 ratio if I were to load up the front bedroom with stuff.
I definitely don't want to buy something to mask the problem. I hope to tame it first. There had to be a reason.
I hate to think it is a manufacturer issue as stated above... that would be a bummer. This is by far one of the nicest built trailers. It has huge I beam frame, and seems built well. I really hope that's not the issue.
5) I'll have mount a go pro in the trailer now.
