wmoses
Jan 16, 2015Explorer
sgrizzle wrote:
with a 3/4 ton truck, you can go a little "heavy" on the tongue...closer to 15%. yes, you need to hit the scales, loaded like you are going camping to see what you have.
good luck!
Agreed. As long as you have the payload capacity go for the higher percentage. Even over the 15% is absolutely fine - there is no upper limit. So far mine has always been just over 15% and I have no sway issues.
Also, there is no need to buy any HA or PP WDH either. Just get the weights right and have a decent mid-grade WDH with anti-sway and you will be fine.
