Downwindtracke1
Jan 18, 2015Explorer
A 3/4 Dodge rear spring pack is firmer than the 1 ton, the 1 ton uses overloads. So you are good there.
An inexpensive, I just paid $100 for 4 leaves on my spring packs for our TT. I did the spring pack installation while changing axels. That should cut down on weight transfer. I didn't have sway issue, but I ended up with a 7" lift when I changed out the #3500 to #5200.
