Zeppe807
Jan 23, 2015Explorer
bguy wrote:
Forgive me if it's already been suggested, I tend to skim a little. Have you checked the trailer wheel bearings for tightness? I believe I read that you have checked the bearings on the truck. If it does indeed turn out to be the trailer that's the first thing I would check, then for worn suspension bushings and cracked welds/mounts in the TT suspension.
Best of luck.
Valid points, and I don't think all of the points were discussed.
I have check the wheel bearings in the trailer, and they are acceptable. I have replaced the bearings in the truck. I do not like the way that the suspension is attached to the trailer frame, and therefore I have kept up with checking that. I have also replaced the bushings, shackles, and equalizers in the trailer.
Thank you for brining that up.
Thanks,
Joe
