Bob_Olallawa
Jan 24, 2015Explorer
With 5 inch difference, important to have the trailer as level as you can. If not on level surface measure front and rear to the ground from a trim piece or the frame if you can use it. With only the one friction sway bar, if it is the trailer that is causing the sway, be ready because you will only have half as much help
