Zeppe807
Jan 25, 2015Explorer
Bob/Olallawa wrote:
You say you had to raise the rear of the truck about 3 inches to set the bars. It is normal to lift the rear to relieve enough weight/pressure to snap up the brackets. If doing that did bring the front of the truck back to unhitched height and the rear down 3/4 inch it sounds like you are close. 3 links loose sounds like 5 or 6 under load which is good too.
Correct, the rig sits level, and handles well, but it rides rougher this way though.
I was wondering if I should have 1400lb bars...?
Joe Zeppe
