DallasSteve
Nov 20, 2023Nomad
My Travel Trailer Fell Down
I was putting yellow blocks under my travel trailer wheels on one side to level it. My lot is not paved, not gravel, just dirt and grass. I did the job and it was great. It was level. Then I was ...
- Nov 20, 2023
Raise it up as much as you can then use jack stands or wood cribbing to hold the a-frame. Raise the jack and put more cribbing under the jack, so you can raise it further.
Honestly, I don't like using lots of blocks under the tires or jack. I typically limit the tires to a couple of 2x? thickness before looking at other sites. I do have a wood stand I made for the jack but it's about 1ftx1ft, so unlikely to slip. It's made of 2x4s, so plenty strong.
If it's your permanent storage site, I would try to level it, so you don't need any blocks.
