Sea_Six
Jun 13, 2014Explorer
Turn a faucet on, then listen. Then turn it off and listen.
If the noise is coincidental with running water it's your water pump. It is normal for it to run in short bursts occasionally as the pressure drops with temperature changes even if there is no water leaking anywhere.
If it's running in short bursts at even, periodic rates, you need to look carefully for water leaks.
