n7bsn
Jun 13, 2014Explorer
Vet Man wrote:sch911 wrote:Vet Man wrote:
Not likely the water pump if you are on city water. Pump should be a different noise then the inverter fan. In hot weather inverter fan will run a lot some are quite some not.
If the pump switch is on it can run even when hooked up to city water.
She said the water faucets were off and not dripping.
But the pump might be running if there is an internal leak in the plumbing
