MorMJS's avatar
MorMJS
Nail in tire, Repair or Replace
Found a nail in my passenger side rear tire. Its not losing air quickly at all, about 4psi in 3 days. Should I just repair or should I replace that tire all together? Tires are Westlake Super ST205/75R14
This is my first TT and first tire issue so im not sure what common practice is.
**nail is through the tread
  • repair from inside with a patch/plug. they will pull the patch through the hole with the plug attached. the plug will seal the tread area and the patch will seal from the inside.
  • Shouldn't be a problem, as long as you don't run it too low and damage the sidewalls.
  • romore wrote:
    If the nail is through the tread it is easy enough for a shop to patch from the inside. A plug will get you to a repair shop but is not intended as a permanent repair. If through the sidewall you are looking at a new tire.
    Forgot to say that the nail is through the tread.
  • If the nail is through the tread it is easy enough for a shop to patch from the inside. A plug will get you to a repair shop but is not intended as a permanent repair. If through the sidewall you are looking at a new tire.
