Path,
I could not ascertain if you have a TC or not from your sig, but if you do, a Hi-Lift jack is not a lot of help. No where to lift except maybe the front winch bumper. If all you need is something to pull T bars from the ground, get a 60 inch model, not a 48 inch. There is a great little add-on that makes your Hi-Lift into a T bar post puller. I have one and it works well if you use your 1 foot square Jack board or one of the plastic leveler blocks as a base in muddy or sandy ground. I think I bought it at Tractor Supply. After buying a tractor, i just pull out the T bars using a heavy chain, the add-on, and hoist the bucket.
jefe
