RDMueller's avatar
RDMueller
Narrow driveway, pull in or back in?
Just brought home the new Wildwood 28' TT yesterday! I knew getting into the driveway would be tight and sure enough, despite turning as wide as I could, the trailer's tires cut the corner thru the grass leaving ruts. The driveway is long but narrow (10' wide) and is perpendicular to the street. The street is a typical neighborhood street, probably about 25' wide. Not helping the problem, my truck is the long bed crew cab Ram, over 20' in length.
Obviously one option is to widen the driveway near the street or put down pavers, but I'm wondering if in a situation like this, if backing might work? I'm new to pulling something this big, so there was no way I was going to try backing in without practicing in an open parking lot first. I'm just wondering if the geometry is such that, when I get good enough at backing, that doing so will allow me to get into a narrow drive when pulling in won't (at least not without leaving the pavement).
I will say, with this truck as long as it is, if parking in a tight parking lot with little room to maneuver and parking between two occupied spaces, I find it much easier to back into the space. If you try to pull in, there is just no way to get the back end over. I have no idea if the same principal would apply when towing or not.
I will probably try making chalk outlines with the exact dimensions in an empty parking lot to try it. But in the mean time, any advice would be great!
