mdamerell
Feb 25, 2015Explorer
boogie_4wheel wrote:
If you can back it in, you can pull it out. And if you can pull it in, it can be backed out.
This is not true in all cases, just ask a semi-truck driver. It's often considered a rookie mistake. If it's tight, it's better to back in. If you are at a truck stop it's why the rigs are normally backed in. Unless the driver can back straight out they, will often get stuck nosing into a space.
Granted a semi trailer is longer but as a rule, any hole you can back into you can pull out of, but not every hole you pull into can be backed out of. A "hole" in driver talk is a parking space, dock, alley, etc.
If you can back, I'd try backing into your driveway. If your neighbor's driveway is directly across from yours you may ask if you can pull up in their driveway and then you have a straighter shot at backing into yours.
