RVcircus
Feb 25, 2015Explorer II
mdamerell wrote:boogie_4wheel wrote:
If you can back it in, you can pull it out. And if you can pull it in, it can be backed out.
This is not true in all cases, just ask a semi-truck driver. It's often considered a rookie mistake. If it's tight, it's better to back in. If you are at a truck stop it's why the rigs are normally backed in. Unless the driver can back straight out they, will often get stuck nosing into a space.
I agree with mdamerell on this one. I used to think the same thing...if you can pull it in you can back it out, but it depends on your surroundings. Our driveway is narrow, steep and cut into a hill, so there's not any room to turn the truck to pivot the trailer. At the bottom of the driveway there a narrow street and a steep hill on the other side, so we don't have the option of cutting corners. I was able to get the trailer out but it was VERY ugly.
44,072 PostsLatest Activity: Aug 23, 2026
