NC Hauler,
Do you mind measuring the on center distance between the perimeter bed holes in your integrated 5th Wheel / Gooseneck hitch set up?
I'm interested in the distance they are from each other lengthwise, and width wise. I'm interested in on center distance from hole to hole only, not from hole to tailgate or hole to front of bed.
After measuring the distance of the perimeter holes front to back and side to side, do you mind checking to see whether the gooseneck hole in the center is equidistant diagonally between all four perimeter holes, of if it is offset/biased forward or rearward in relation to the perimeter holes?
I would very much appreciate knowing this information. The Ram website and the Ram dealer are both useless in these regards.
Thank you, and congratulations on your new tow vehicle!
