rockhillmanor
Jul 07, 2017Explorer II
I know you said you bought a new sewer hose but did you buy the Rhino? IMHO the ONLY sewer hose to have on board! Makes a big difference on your dumping experiences! :B
Rhino Sewer Hose Kit contains all the connections you will need. As some are required at CG's. The hose is rigid and expands and contracts to what ever length you need and is 'real' easy to handle.
____
Sidewinder Support: This is the sewer support that if you are parked for a while you will be able to hook up from any height or angle and/or around trees. No more having to pick up the hose to get it to drain when ground is lower than sewer hook up.
____
