2horse's avatar
2horse
Need 1 more inch of clearance
I am purchasing a new trailer that is 11'0" with A/c on top. My barn opening is 10"11.5" Is there any quick way to lower about an inch? This will only be going in barn for winter. Would removing a/c shroud help any? Any help is appreciated. Thanks
  • Are you using book literature heights or actual measurements. There could be a difference
  • The a/c shroud usually sets directly on the a/c innards so that's an unlikely option. Reducing the air pressure in the tires is a no brainer. As long as the rims are not riding on the bottom of the tire it will be OK for short distance movements.
  • Unfortunately a/c unit is right above axles. I thought of that too. Thanks for replies. It's a good deal I don't want to pass up but it has to fit
  • 2x on airing down the tires, one other option would depend on where the AC is mounted,
    if way forward, lower the hitch if you have an adjustable one.
    If the AC is way aft, you may gain a little by raising the hitch.
  • Maybe lower the air pressure of the tires....not completely flat, but just enough to roll 'er in. Then re-inflate. And, like you said, maybe remove the AC shroud at the same time. Might work.
