westend wrote:
Based on your description, I would suggest to pull the front seam back up, spread some adhesive on the roof decking, and apply another piece of Eternabond to the seam. Do not staple the membrane, that will only cause holes in it.
+1
Since you already have a repaired seam I'd peel it back up, glue, and install Eternabond again. Avoid using staples.
How's the structure of the roof? Are there any soft spots developing? The rest of the roof looks solid other than the wear, so I'd recoat. When I did my roof I setup scaffolding, but if you don't have a convenient area to work I'd suggest ladders/makeshift scaffolding.
