Bedlam
Aug 09, 2017Moderator
The nylon straps will age out quickly and fatigue.
Unfortunately, quality tie down brackets and turnbuckles can cost more than a used camper. Fortunately, you can reuse them on the next camper if you stay with the same truck. If you switch trucks, the tie downs will most likely not fit but you will be able to use the same turnbuckles.
BTW: If the camper was designed for a long bed truck, the center of gravity will be behind the rear axle and cause your front end to float.
