jungleexplorer
Jul 29, 2014Explorer
jerem0621 wrote:
Hmm....
I pulled a 7000 lb 32 ft TT with my old 97 F150 with NO problems. I upgraded to a dually and pretty well hated it.
What's the issue here? Does the rig not pull well? Is your friend just wanting to help you spend your $$$?
Upgrade if you want, but I'm not sure it's needed...
Well, my particular truck is probably the most fuel efficient stock model of gasoline Chevy made in the 2000s. To achieve great gas mileage, they had to gear it up really high in the rear end. This means that it was not intended for pulling. Can it pull? Yes. The engine certainly would have no problem, it has the power. Like a chain that is only as strong as the weakest link, a truck is only as strong as it's weakest component. The weakest component in my truck is a thing called an "Automatic Transmission".
Basically, I want a TV that I don't have to worry about. I want a TV that I could jump in tomorrow and drive to the Arctic ocean pulling my TT and not have to worry about it putting too much stress on it.
My Dad has a 2005 Dodge Ram 2500 with the 5.9 diesel. He gets 23MPG on the highway empty and 16 towing a TT. I am probably gonna go with something like his truck, but I thought I would ask around and see what else out there that can do the same, because the 2005 Ram 2500 with the 5.9 diesel are a hot item around my area because of the oilfield and hard to come by at a decent price.
44,068 PostsLatest Activity: Apr 17, 2021
