AirForceAngler
Jul 30, 2014Explorer
kodiakcanuck wrote:
Item 2 and 3 are extra precautions only, and not necessary. You already have a tranny cooler, keep it in TOW/Haul mode and it locks out overdrive and keeps you in the 3rd or 4th gear.
Item 4 needs to move to item NUMBER 1. You NEED a brake controller for panic stops and down hills. This should happen before you change the rear end....:E
Tow/Haul mode does NOT lock out overdrive. It only changes the shift points and raises the pump pressure for firmer shifts.
44,068 PostsLatest Activity: Apr 17, 2021
