jerem0621
Jul 31, 2014Explorer II
2112 wrote:This is just who I am. I do tons of research about every aspect of any venture I engage in...That's all good but be aware of analysis paralysis. You can analyze something to the point of being stuck, unable to make a move for fear of making the wrong move or unsure of what the right next move should be.
In this case it's use the truck, adjust as needed, enjoy the journey and see where it takes you.
So correct...analysis is good but there needs to be a good enough and then take action!!!
In the OP's case I would get the transmission temp monitored and get a good brake controller. Then I would just pull the trailer and see if I was satisfied with the performance before I did anything else.
Thanks!
Jeremiah
44,068 PostsLatest Activity: Apr 17, 2021
