jungleexplorer
Jul 31, 2014Explorer
jerem0621 wrote:2112 wrote:This is just who I am. I do tons of research about every aspect of any venture I engage in...That's all good but be aware of analysis paralysis. You can analyze something to the point of being stuck, unable to make a move for fear of making the wrong move or unsure of what the right next move should be.
In this case it's use the truck, adjust as needed, enjoy the journey and see where it takes you.
So correct...analysis is good but there needs to be a good enough and then take action!!!
In the OP's case I would get the transmission temp monitored and get a good brake controller. Then I would just pull the trailer and see if I was satisfied with the performance before I did anything else.
Thanks!
Jeremiah
Yeah. That is what my plan is, but if it does not cost a lot to get a larger trans cooler I will do that too (it can't hurt anything).
Now I am looking at some towing mirrors. My mirrors are not far enough out and I have a huge blind stop that makes me real nervous. There is a set of extenters that slide over the existing one on Amazon for $40. Anyone ever used these kind?
44,068 PostsLatest Activity: Apr 17, 2021
