APT
Jul 31, 2014Explorer
Trans coolers are closer to $50 than $500 for parts and trans shops should install for 2 hours labor.
There is little point in changing the rear axle from 3.23 to 3.42. If you are going to swap, go for 3.73 or 4.10. GM offered both ratios in pickups and SUVs using that rear axle.
Skip the tuner/aftermarket chip. There is little extra power to be made over stock under 3000rpm. Save your money for when you can upgrade the whole truck to something with more transmission gears.
44,068 PostsLatest Activity: Apr 17, 2021
