majorgator
Aug 07, 2014Explorer
My trans temp is around 210 towing light loads and gets up to 230 or so on heavier loads. Admittedly, that's a bit high, which is why I have a new trans cooler on the way. There's no problem with 200 degrees. I found a chart for trans temp ranges a while back. If I can find it again, I will post.
EDIT:
Here's a copy/paste from the chart I was referencing...
Transmission coolers help extend the life of your transmission fluid and can prevent transmission failure from overheating.
At 240° varnishes form and transmission life expectancy is cut in half.
At 260° the transmissions internal seals and rubber parts harden and major damage starts.
Above 295° your transmission starts slipping, clutches burn out and carbon forms.
With each 20° drop in operating temperature, your fluid and equipment life doubles.
EDIT:
44,068 PostsLatest Activity: Apr 17, 2021
